cannot make calls and does not charge
You likely need a new charge port flex. The charge port, aux port, bottom mic and antenna are all part of the same flex and a repair guide can be found here. The part is pretty inexpensive, just be sure you double check the seller reputation.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 39
