My camera wont turn on and it wont charge
When I have my camera plugged it to charge the camera does not turn on, I can not get my camera to turn on. What could be wrong??
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The most likely causes for your problems are that something is wrong with the charger,charging port, battery, or it could be something wrong with the display screen making it appear to be off.
You should probably check the Troubleshooting Guide for help. It covers both of these problems. Also if it is just the screen then the Display Screen Replacement Guide could help your problem.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 14
今までの合計 1,139
