How do I replace a Fan Relay
The engine light is on so I had a diagnostic done. I have a P0480, which seems to indicated a fault in the Fan I control electrical circuit. How do I replace it. Thank you.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The radiator fan relay is located within the engine compartment fuse box. This is under the hood on the driver's side. I'm not sure which year car you have so I can't tell you for sure, but in your owner's manual (and possibly on the fuse box itself) you should be able to figure out what relay corresponds to your radiator fan. You should be able to find a suitable replacement at any auto parts store or website.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 7
過去 30 日: 29
今までの合計 5,603
