touch screen not working
touch screen on nook not working
Did you already try to hard reset it?
To Hard Reset NOOK HD/NOOK HD+, complete the following:
Confirm the device is powered off.
Hold the Power and Home key simultaneously.
Release the Power and Home key once the NOOK logo appears. A Factory Reset prompt will appear.
To continue, press the Home key.
To exit, press the Power key.
このアンサーは役に立ちましたか?
I did a factory reset, the keyboard still isn't working. I can't select some of the letters on the keyboard.
I also have a non-responsive touch screen, although the top menu lights up when touched after the power button is first pushed. Did a reset and factory reset. Still, no touch screen. Would it be more likely a screen problem or a motherboard problem?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 13
今までの合計 2,346
