needs a service error 130
machine starts then shows needs service error 130
この質問は役に立ちましたか?
Vanessa Bourne most likely (will confirm after you identify your model properly)
130. (10000010) Rotor Position Sensor Error
The Motor Control Module has found an error in the pattern received from the Rotor Position Sensor. Likely causes of this fault are a bad connection on the harness between the Rotor Position Sensor and the Motor Control Module, or a faulty Rotor Position Sensor.
Primary Source: Wiring.
Action: Check for corrosion on the RAST connector of the Rotor Position Sensor and the Motor Control Module connector.
Secondary Source: Rotor Position Sensor.
Action: Check the Rotor Position Sensor with an R.P.S. tester. Replace if faulty.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Quaternary Source: Rotor
Action: Ensure the correct rotor for this series of machine has been fitted
このアンサーは役に立ちましたか?
hallo there - in New Zealand we have a machine known as a 612
- the rps is very poorly designed ( worse than the older machines )
the horisontal wiring socket - traps soap powder
you might be able to separate the wiring from the rps & clean it up
using something like CRC etc ( & re-fit it etc )
--------------> better still there is a new part available with an integrated wiring loom
you need to run the new sub cable up to the Motor Controller Module and plug it in
and you need to cable tie the sub cable to the existing loom with afew modest cable ties
このアンサーは役に立ちましたか?
130 is rps fault
Could likely be corroded rps
Other less likely reasons but still possible are
Loose rotor
The nut on the shaft sometimes comes loose
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 8
過去 30 日: 62
今までの合計 18,742
3 件のコメント
Hi,
What is the model number of your washing machine?
jayeff さんによる 共有
WL26CW2 is the model number
Laura Lee Midgett さんによる 共有
Aquasmart 8kg
Model Number- WL80T65CW
Product Code- 93114-B
JMaree さんによる 共有
