Why is my screen barely visible?
The screen for my Garmin device is not very visible, and is much worse than when I first bought it.
Try adjusting your screen brightness, if that does not work the device's backlight may be starting to die.
このアンサーは役に立ちましたか?
Try adjusting the contrast also. If that doesn't solve the issue, then there might be something wrong with the display itself. Then, you would have to replace it.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 5
過去 30 日: 14
今までの合計 368
