メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5cの修理情報とガイドです。モデル A1532, A1456
1233回答 すべてを表示
I broke the adhesive strip tab on the battery
As i was trying to replace my charge port i broke the adhesive tab on the battery and can't figure out how to remove the battery without the tab. Can someone help? It is urgent!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
7件の回答
ベストアンサー
This is an old question but I thought it would be a good idea to remind people that if the adhesive tabs are broken, the safest thing to do is to remove the logic board before attempting to pry the battery out (heat or no heat). Remove the port & speaker too if you want lots of room to work from. That way you will minimize the deformation to the battery.
iPhone 5cのロジックボードの交換
iPhone 5cのLightningコネクターアセンブリの交換
The iPhone 5C has tiny surface mount components near the edge of the logic board near the battery connector. If you pry the battery from there, you can easily knock some components off the board. They are minuscule and once separated from the board, are indistinguishable from dust...seriously!
iPhone 5c Lightningコネクターアセンブリの画像
ガイド
難易度:
難しい
45 minutes - 2 hours
iPhone 5c ロジックボードの画像
ガイド
難易度:
中レベル
1 - 2 hours
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
You have to do it the hard way.
Unless you remove the speakers and somehow pick out the remaining strip and keep pulling.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
I'm sorry to be ignorant, but what is the hard way?
さんによる
My hard way is using a heat gun and prying the battery from the bottom left and deforming making it not reusable.
さんによる
I was able to "somehow pick out the remaining strip and keep pulling" though it did require bending the battery a bit becuase the strip broke waay under the battery.
さんによる
コメントを追加
Hey Colin Sweet,
Just use som heat and try to pry the battery up. Do this very carfully.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Remember to do this from the back of the phone and not the battery side. My brother once fried his battery by heating it from the wrong side.
さんによる
Haha, ofcourse Lauren. Never apply heat into the phone, just apply from the back.
さんによる
コメントを追加
Before you nuclear, try the tabs again.
Look at the bottom of the battery towards the charge port for the white adhesive. If you can grab it with tweezers, you can SLOWLY pull on it and still get it out.
If you have to go nuclear, watch out for the power flex at the top right under the battery.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Here is a method a friend of mine developed - https://www.youtube.com/watch?v=gkCyl7kR...
He uses fishing line to pull away at the glue.
Also this method that uses a metal wire looks promising - https://www.youtube.com/watch?v=W5GzU11q...
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Thanks for the links! My co-workers were getting tired of me swearing at the damned adhesive strips. They thank you for the links, too.
さんによる
Thanks man! I also swear really loud at home that the neighbours get annoyed until i found this. Thanks again m8!
さんによる
コメントを追加
just as a point of interest, most of the time i get iphone's with charge port problems, its just dirt stuck in the port that stops the charger going in properly.
try plugging the charger in, if it doesn't sit flush against the bottom of the phone, its probably just fluff inside.
try pulling it out , CAREFULLY with tweezers or something else that may fit in the charge port
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
The same thing happened to me today with my first-gen SE. I was able to get the battery out by putting some 99% isopropyl alcohol under the battery to weaken the adhesive, then pulling a piece of dental floss under it to cut through the adhesive. I also used a plastic pick to pry the battery a little bit.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Colin Sweet さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 26
過去 30 日: 83
今までの合計 21,133
