メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2014年9月19日に発売されました。この5.5インチサイズのスクリーンをもつiPhoneは、iPhone6の拡大サイズ版です。
Touch and power button issues
Having some weird problems after replacing the screen on this iPhone. To start the screen did not work at all when I received the phone. During the repair I tore the cable that the home button connects to. I replaced that cable and now after replacing the screen the touch almost never works. I can try to swipe over to the unlock screen but it will only swipe over once or twice every 30 attempts. Also the power button sometimes just doesn't work at all and sometimes it works fine. Currently I'm going over the mother board looking for any damages but so far I have nothing. Anyone have issues like this before or know of a solution? I tried a completely different screen and the same problems are happening.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
The touch problem sounds a lot like a common problem in the iPhone 6 (plus), where the touch IC no longer makes proper contact.
Unfortunately the only permanent fix is to resolder the entire thing, which requires quite some expert skills.
It's kind of hard to find decent info on this problem, since Apple won't acknowledge it.
For more information on what exactly causes it and how to fix it: http://mendonipadrehab.com/entries/gener...
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Definitely a good read. Thanks for posting that link
さんによる
Thank you so much for your help time to test my soldering skills
さんによる
コメントを追加
最も参考になった回答
Clean the digitizer and lcd sockets with 90% isopropyl alcohol. Make sure you've secured your connections and make sure you're using quality parts
iPhone 6 Plus スクリーンの交換
iPhone 6 Plus Screen
I would also check and see if the phones been water damaged. That would also be a 90% isopropyl alcohol clean. As for the power button. Try to clean it, you may need to get another flex cable
iPhone 6 Plus Home Button Link Cable
iPhone 6 Plusの電源ボタンケーブルの交換
Replace a screen compatible with iPhone 6 Plus. Includes all of the small parts preinstalled in the assembly. Features a 5.5 inch 1080 x 1920 pixel IPS LCD Display, Front Glass Digitizer Panel, Front Camera Assembly, Earpiece Speaker, Home Button Link Cable, and LCD Shield Plate.の画像
製品
$49.99
Replace the cable that connects the home button assembly to the logic board compatible with the iPhone 6 Plus. This cable follows a channel in the LCD shield plate. Part #821-2658.の画像
製品
$14.99
iPhone 6 Plus スクリーンの画像
ガイド
難易度:
中レベル
1 - 2 hours
iPhone 6 Plus 電源ボタンの画像
ガイド
難易度:
難しい
45 minutes - 2 hours
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Power button is working fine after giving the it a good cleaning
さんによる
Oh, good! Glad you got it sorted
さんによる
コメントを追加
回答を追加する
Jeremy Byers さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 2,367
