メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Kenmore 電子レンジの修理および分解ガイドです。
Why is my microwave dead
Is there a fusible link or internal breaker? I shorted my microwave out changing the lightbulb over the range. Now there is no power anywhere on the microwave. The outlet still has power.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
4 件のコメント
Please give us a model number
さんによる
Model number is 85513
さんによる
I have a kenmore model 721.80803400 and just replaced the light bulb. It got stuck and broke off. I did not unplug the power and did stupid mistake of tweezers to remove the plug and bang no power. Tried to reset the circuit breakers in the house (main) on and off and then checked the plugs outlet and they work. Tripped the wall and the appliances all work but not the microwave. Is there another switch on the microwave to hit power?
さんによる
Does anyone have the Manuel for this microwave? Size? Power? Do you think it's good? Thinking of buying a second hand one. Thanks
さんによる
コメントを追加
3件の回答
ベストアンサー
@luker your microwave has a fuse on the inside by the power supply. That's where I'd start. Double check your model number. I would have expected a 3 digits prefix. See if it does show anywhere. Reason why I ask is that Kenmore really does not build microwaves but those are rebranded. Could be made by Samsung as well as many others. Anyhow, fuse should be in the same vicinity as part 5001 in the image.
画像
このアンサーは役に立ちましたか?
スコア 3
4 件のコメント:
Thanks for the help. My wife will be happy if I can fix this.
さんによる
thank you, but where is the fuse
さんによる
@nier101
What is the model number of the microwave oven?
さんによる
My microwave is a Kenmore model# 970-86113-001
さんによる
コメントを追加
You might need to look at your house power Panel to see if your Microwave has a dedicated circuit breaker to see if is tripped. Or if there is a power plug trip circuit (a little red button) on the power outlet. If that tripped then your Microwave might not be getting power. Press the red button or if it is a circuit breaker reset the power.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
The outlet that it is plugged in to still has power so I see no sense checking the hydro panel. Any other ideas of an internal fuse or something of the like.
さんによる
コメントを追加
Hi Luke. In 2016 you posted on ifixit that you shorted your microwave while changing a light bulb. I just did the same thing. How did you eventually fix it? Replace an internal fuse?
—Frank
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hey Frank, I had the same problem. Opened the microwave, checked the fuse. It was blown, bought @ Homedepot - $3.50 package of 2 - 20A/250V microwave fuse. Cheap fix.
Dave
さんによる
コメントを追加
回答を追加する
Luke さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 18
過去 30 日: 106
今までの合計 18,123
