メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Canon PowerShot SX280 HSは、20倍光学ズーム、内蔵Wi-Fi、GPS機能を搭載した1200万画素のコンパクトなポイントアンドシュートカメラです。
Stuck Camera Lens Cover
The camera lens cover no longer opens when the camera is switched on. Tried replacing and removing battery powering down when lens extended. Reset to factory defaults doesn't make any difference. Tried lightly brushing the cover and using a hoover close by to remove any "specks" of dust / debris that may be preventing the mechanism working. You can easily move both halves of the cover assembly manually with a soft brush so it is not 'jammed' in that sense.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Its possible that some debris found its way in the mechanism or gearing that operates the lens barrier doors when the camera powers up. I would suggest to have it looked at by a repair shop there are small springs and parts that make up for the operation of barrier doors. If your mechanically inclined and can repair it yourself with some patience, some of the barrier door assemblies can be removed at the front of the lens assembly. It may come out as a one piece unit or the doors are part of the lens barrel assembly. I have 13 years experience in the camera repair field used to see this problem on quite a few cameras, found anything from a grain of sand caught in gearing to timing being off from impact damage. Hope this was helpful for you.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hi,
Is it always the case that service centers would recommend to replace the whole lens?
Thanks.
-Apple
さんによる 共有
コメントを追加
回答を追加する
John さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 41
今までの合計 2,357
