メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
プールとは、水泳や水中レクリエーションを目的として水で満たされた容器です。
Clean large amount of leaves from pool bottom
I have last fall's leaves at the bottom of my pool. What is the best way to clean them all out?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
5件の回答
ベストアンサー
I used to just drain mine and get down there with a shovel and hose to wash all the dirt out. Trying to balance your chemical and get rid of all the growing stuff is a nightmare. Better to just start over from fresh. If the walls feel a little or a lot slimy, that's bacteria growing. I used a high pressure water sprayer first with soap and a disinfectant then clean water. Remember to clean your filter and pump and disinfect.
このアンサーは役に立ちましたか?
スコア 5
コメントを追加
画像
The most common way of removing leaves from the pool — the leaf rake or leaf skimmer. You have to use it manually, and it's relatively cheap — so you don't have to worry about replacing it often.
However, it requires extra effort from your side to clean the bottom portion of your pool, which is where the real trouble lies. You'll have to spend a lot of time and effort to scrub the bottom surface to clean.
Maybe these '''''Leaves Cleaning Hacks''''' give a detailed picture of Hassle-free Cleaning.
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
Nice Post Keep posting
さんによる
コメントを追加
I would recommend using a deep leaf net to get out the majority of the leaves. Using a pool vacuum and sending that much debris into your filter will just immediately clog it.
Once the majority of the debris is scooped out manually with a leaf net, then I would use your automatic pool cleaner to finish the job. If you don't have an automatic pool cleaner you can use manual pool vacuum.
Sounds like you're opening the pool for the season. Enjoy.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
I would suggest using a deep pool net do not try to vacuum the pool because it will get plug also remember to clean all the baskets including the pump for better circulation
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Use a deep leaf net to get everything you can out. Then brush your pool thoroughly, and vacuum it thoroughly. Backflush your filter until water is coming out clean. Then resume normal filtration, shock your pool, and once chlorine levels have returned to normal you can get the rest of the chemistry in line. Clean ALL baskets! Skimmer and pump.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Bill Davis さん、ありがとうございました!
統計データ:
過去 24時間: 9
過去 7 日: 25
過去 30 日: 108
今までの合計 64,217
