メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
XFX 680チップセットの機能を削減した低コストバージョン。
RAID 0 gone bad.
any ideas to get a raid 0 array working again? the drives are fine and all the data is on them, but raid doesn't want to recognize them. someone suggested rtools, but a demo version only lets you recover 64kb files. key? other options?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
did I mention this is for an XFX board?
read: running Windows 7.
さんによる
コメントを追加
1 件の回答
ベストアンサー
If the RAID set is broken, yet you can read the data, your best option is to copy off what you can/need.
The only way I know to get a broken RAID 0 set back working is to set it up as new - which means the existing data is going to be erased.
RAID 0 is all about speed and performance - there is NO data redundancy... Depending on how your RAID controller and RAID 0 set was created, you may only lose files split across the drives (JBOD mode). If your RAID 0 was in Striped mode, you will probably need pay for something like rtools.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
that's what I figured, I'm trying to decide if rtools is worth it because I don't actually remember what's on them. If I knew, I'd be able to decide. Oh you, impasse!
さんによる
さんによる
R-Studio is a great thing. You will certainly be able to use it for other things beside this problem.
さんによる
コメントを追加
回答を追加する
tabormeister さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 9
過去 30 日: 26
今までの合計 4,861
