メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Canon Pixma MP480は、2008年に発売されたカラーインクジェット方式のオールインワンフォトプリンターです。
printer is printing a double image
double image on printing
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
3 件のコメント
My MG 5620 has developed poor print quality. It is like a double image -- perhaps there is a problem with the alignment of the ink-jets?? I have tried running the cleaning procedures and changing the ink cartridges. But that hasn't helped. I do not want to trash it -- if I can do something to fix it. Please help! Thanks!
さんによる
Hi @hpac102 ,
Did you do a printhead alignment - scroll to p.193 to check if this resolved the problem? You didn't say.
さんによる
I have the same problem on a Pixma MG5450 and have tried everything - cleaning, deep cleaning, auto print head alignment and manual alignment 3 times. Any ideas? I'm keen to fix it rather than just throw it away
さんによる
コメントを追加
1 件の回答
ベストアンサー
Try using it on another computer to rule out a driver issue. If it double prints on another computer, you have a hardware issue. It would be nice to get a photo of the problem as well: iFixitでの質問に画像を追加する方法
If it’s just the driver acting up, you can fix it by removing and reinstalling the drivers. Make sure to use the ones online from Canon and not the CD, since the CD is never up to date when the printer is sold. If it’s a hardware issue, you’re going to spend more trying to fix it then it’s worth, so you’re better off getting a new printer.
It may be possible to fix it, but usually when you have an issue like this it’s generally serious and needs expensive parts to repair.
Also PS: Do yourself a favor and find yourself a nice HP or Brother mono laser printer, unless you genuinely need color. Inkjets only make sense if you print photos.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
james nelson さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 35
今までの合計 1,409
