メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2014年8月に発売されたLenovo Y50-70 Touchは、LenovoのYシリーズノートパソコンの1つです。専用のグラフィックカードと15.6インチのタッチスクリーンを搭載しており、ゲームに特化したモデルです。
Screen flickering (Might be link to GPU)
Hi,
Since a month or so now my screen seems to be flickering. Sometime randomly, sometime when stuff happen on the screen like scrolling a pdf directly in gmail.
I'm suspecting it could be link to gpu because when i disable gpu acceleration in chrome, the problem seems to be less likely to happen
Drivers all updated. I just flashed the BIOS to update it with Lenovo's tool.
The flickering don't happen when i move the computer, which suggest to me that it's not a cable problem (Moving it around should increase the chance for flickering ?)
Any suggestion ?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント:
Hi, Can you connect an external monitor to see if you have a stable picture?
さんによる
It was still happen but more stable when an external screen plugged (It seems that the external screen don't flicker but the screen just stop receiving feed for an instand and become black). I think i found the cause, when i disable the integrated video card, the problem stop happening. It seems to come from the power switch between the integrated card and NVidia
I tried to downgrade my driver to the last one available on Lenovo (Manufacter seems to customize their drivers sometime) and it seems to be more stable now, but still happening.
If someone has a better idea...
さんによる
Hi, Try starting your laptop in 'Safe Mode'. If the screen doesn't flicker it is a driver problem. If it still flickers it most probably is a hardware problem. Also really way out thought. Is the laptop's cooling vent clear and unobstructed and can you 'feel' that the fan is running? I'm wondering if it may be heat related.
さんによる
コメントを追加
2件の回答
I found a way to eliminate the problem so far, by choosing the balanced power option instead of performence. (If you want to keep the perf plan, go in the plan setting and change Intel(R) Graphics Power Plan to balanced on battery, it seems to mitigate the problem !)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Find a reputable soldering laboratory with ability to refurbish BGA components. It will be fairly simple procedure for them and will repair the connectivity issues between circuit board and graphics processing unit.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Alex さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 19
今までの合計 2,062
