メインコンテンツにスキップ
2.2 GHz (Turbo Boost使用時最大3.4 GHz), 2.5 GHz (Turbo Boost使用時最大3.7 GHz)もしくは2.8 GHz (Turbo Boost使用時最大4.0 GHz) L3キャッシュで6 MBのクアッドコアIntel Core i7プロセッサ
773回答 すべてを表示
Spilled Water Turns On But Stops at Logo Screen and Progress Bar
A month ago in a galaxy far far away....
I spilled water on my baby because I am a clumsy Wookie and my fur caught my cup like a less agile Ewok. As I have not finished my level II training in force manipulation to reverse these water molecules inertia the water went into the keyboard and my girl shut down almost instantly.
As you can imagine I reacted like this (https://youtu.be/A6mHRqYTKhY) then I flipped it and let it air dry for 4 days etc...no luck nothing would turn on. This was like a month+ ago.
Wookies can get pretty mad sometimes and smash things so this Wookie went to meditate with some Wookiefoot and let it sit while I remained in silent contemplation.
Eventually I took her to the Apple store a few parsecs away and they gave me ZERO Wookie love for my sob story while still under factory Applecare etc.. flat fee of $1200+ credits...they did reset the PRAM and held down a bunch of other buttons then it started turning on again but currently it does not fully boot.
I apologize I probably should have taken a hologram to show boot sequence before tearing this apart to attempt to clean.
Ultimately, this Wookie has a few questions if I can ask any kind beings transmit me some data:
  1. Am I wasting my time...should I just order a new board myself?
  2. I assume I cannot ever get this covered by extended Applecare now that I took it in to Apple..it has a couple of the red dots slightly colored now also...is this correct?
  3. If I am not wasting my time I was hoping someone could point me to the part of the board to focus on cleaning with ISO 99%?
  4. I was also wondering if I really need to remove the heatsinks etc to clean?
So here I am...I have a new hope so I would also like to know if someone could point me to a new logic board since I may have to do that if this phantom menace persists.
Kind regards,
D
Update (04/05/2016)
Well..no luck I bathed it and scrubbed it with 99.9% iso.
Here are my results (after another cmd+r+p) while holding shift key down it almost finishes the bios load:
https://www.dropbox.com/s/4e9alakyppih14...
Should I abandon this or get ultrasonic cleaning maybe?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
最も参考になった回答
Goodness gracious Wookie. Try replacing the upper case first. If that doesn't work, try the logic board. Don't waste your time with Apple. Their replacement parts are super overpriced.
You may need to remove the heatsinks on the logic board, but while you're at it, you might as well replace that stock thermal compound with some Arctic Silver 5.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
So upper case can cause that type of boot error?
さんによる
Sometimes, if there's some damage to the keyboard (the keyboard and upper case are one unit), then it can cause various inputs and whatnot. If it's not the keyboard, then the logic board is next to go. Hope this helps!
さんによる
Thank you. No luck when disconnecting the top case by the genius bar.
さんによる
コメントを追加
Hold that thought!
Before you go nuts here how about disconnecting the keyboard ribbon cable from the logic board and then use a USB keyboard & mouse. The only trick here is you'll need to use the power pads to start your system see if you can get the system to boot up this way.
I think you'll find the system will still react the same as I suspect you likely have a damaged SSD from the water spill.
Here you could try using a USB thumb drive that you've setup as a bootable drive using a friends Mac. If the system boots up using it you have isolated the problem down.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks for this reply. I had genius bar disconnect the top case today and had the same results.
I just took a local service provider to have a look. I will not pay Apple a flat fee for this inferior product to be repaired.
It is 2016 and a few ounces of liquid for a few seconds can easily be prevented with a better membrane design or how about hydrophobic coating on the logic board?
Will know more in a day or two. Really appreciate the help.
D
さんによる
コメントを追加
回答を追加する
Damian さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 299
