My phone is still at huawei startup logo
my phone is not start it is still hang on Huawei logo and after 10 min its atomatically power off
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Try following the steps specified here, it will tell you how to perform a factory reset via recovery and restore the system software on the phone:
http://www.hardreset.info/devices/huawei...
Make sure you charge your battery fully before doing any of these.
このアンサーは役に立ちましたか?
Initially facing the problem but after a lot of research finally found a proper solution.
Huawei stuck on boot screen, huawai hang on startup logo problem solution
Solved my problem bt this hope this will help you also.
To fix this problem you have to reboot your smartphone.
このアンサーは役に立ちましたか?
I perfome hardreset on my huwaei G525-U00 but it is still stuck on huwaei logo
このアンサーは役に立ちましたか?
過去 24時間: 5
過去 7 日: 16
過去 30 日: 33
今までの合計 55,418
6 件のコメント
it is not helpful
manalotojohn26 さんによる
I have the same problem too with my Huawei Ascend D1 Quad XL phone.
I tried to hard reset it but, it suddenly stops at “Huawei Ascend”. (It does not stop at its logo, actually)
I can’t turn it off. Even pressing the power key button does not work.
Respect post. Please help.
Gwapo Swabe さんによる
my huawei is blank only showing the logo on screen, cant seem to be able to switch it off.
ntombifuthi nana さんによる
My y9 2019 is hang with logo charger and never turn on please help..
AirPro Cebu さんによる
my NCE-AL00 is hanging with huawei logo and not switch on
Daniel Retaa さんによる
1以上のコメントを表示
