メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
RCA 10 Viking Proの修理ガイドです。キーボードが着脱可能なAndroidタブレットであり、モデル番号RCT6303W87 DKで識別できます。
How do I replace a cracked screen?
My daughter has a 10.1 Inch Rca 10viking Pro Rct6303w87dk tablet. Her screen is cracked and only the left side of the touch screen works. How do i replace the screen?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 53
17 件のコメント
Is my RCA 10 Viking Pro a total loss?
While traveling the touch screen got cracked and also there is no touch response from screen.
Keyboard response is still good. Thank you for answering my question.
Just got it last Christmas... :(
さんによる 共有
What can i fix my crack scr
een.
さんによる 共有
My screen is cracked on left side. How can I get it fixed?
さんによる 共有
Hi my i drop my tablet on my siramic floor and it crack it still turns on but cant do anything were can i get it fix ?
さんによる 共有
I have this tablet but the problem is that I have cracks inside my tablet and it doesn't work but you can turn it on and off.
さんによる 共有
12件以上のコメントを表示
コメントを追加
2件の回答
ベストアンサー
Just remove the screen frame from the backing using a hair dryer and guitar pick. There is a small seam around the screen that separates the halves. Once you work your way around the halves will come apart but careful there is a ribbon cable still attached inside. Don't break it. Using tweezers pull up on the connectors on the ribbon cables for the LCD and the digitizer to disconnect them from motherboard. Then slide a flat tool under the battery and gently free it from its glue on the back of the LCD. Keep its cable attached to the motherboard. Then unscrew the motherboard from the frame and remove the adhesive holding on the antennae cable onto the back of the LCD. Basically just free anything stuck to the LCD. Now flip the motherboard and battery onto the backing and set aside. Using a guitar pick carefully go around the edge of the LCD screen to free it from the clips in the frame. It will come out - be gentle or bending it will break it. Lastly using guitar pick and hair dryer on the front sides go around under the glass digitizer and free it's glue from the frame. Buy some cell phone adhesive 1-2mm to glue new digitized on then reverse everything and connect it all and fit it back together. Make sure it's s clean environment with no dust or hair.
このアンサーは役に立ちましたか?
スコア 17
5 件のコメント:
this comment right here is useful for any phone model and is a mini guide in itself for screen replacement. I fix screens also. thank you sir for this informative answer
さんによる 共有
does it really work?
さんによる 共有
Where do I get a replacement screen?
さんによる 共有
What can I do for my tablet I was run to my room and I jump on my tablet on ancent and my screen on my RCA is cracked
さんによる 共有
That was really helpful, all the grandchildren are once more giving me time to take a snooze zzz. OOPS spoke too soon, now where did i leave that guitar pick.
thanks from rabthehat
さんによる 共有
コメントを追加
The screen is very easy to replace,If you order a new digitizer from china it will come with the tools as well,At first you unscrew the tablet it will be a total of 7 screws,Unplug the the broken digitizer,then take a guitar pick from the top and work it into the broken screen it will be kind of hard at first,work the old screen out.clean the outside of the old screen old glue from the tablet.After that everything els will explain itself,remember do not break the retaining clip from where the the new cable will plug in to the tablet it just lifts right up it doesn't pop off but lifts straight up!
このアンサーは役に立ちましたか?
スコア 8
2 件のコメント:
This is a RCA Tablet
さんによる 共有
Where can I buy RCA Viking 10 screen mine is cracked in Nigeria
さんによる 共有
コメントを追加
回答を追加する
happyfaces126 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 35
今までの合計 29,550
