メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
SoundBotのポータブルワイヤレススピーカー。最大12時間の音楽再生が可能。ハンズフリー通話、内蔵マイク、充電式バッテリーを搭載。モデル番号はSB571-BLK/BLK。
Why is there static noise?
There is a horrible static sound whenever I turn my speaker on. No matter the volume, high or low, I can’t hear the music over the static sound. Do the speakers need replacing, or could something else be causing the unwanted static?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 8
3 件のコメント
The answer said nothing about hard wired speakers which is where my problem is. That said, since it is an old Sony receiver, and static is in all speakers, is is possible the receiver is to blame or is this a wire problem.
さんによる
My hoverboard has been making a static noise since I went into a ditch, on a narrow pathway. I don't get what is the matter , but I need to know asap if the speakers need changing.
さんによる
static noise only on set ups that is it for over 3 months
さんによる
コメントを追加
5件の回答
ベストアンサー
Hi,
Try connecting the speaker to a music source using a stereo audio cable plugged into the Line In Audio socket of the speaker and the headphone socket of a mobile phone (for example).
If there is no noise, there may be a problem with the Bluetooth connection. Remove any pairing connections stored in the speaker and also the Bluetooth device (e.g. phone) (see previous answer to you with User Guide link) then re-pair with the Bluetooth source and see if it is still noisy.
If it is still noisy, remove the Bluetooth connection 'stored in the speaker and try pairing with a different Bluetooth device, (ensure that the 1st Bluetooth device has the Bluetooth turned off) and see if the noise is still present.
If there is noise when using both the Bluetooth and the stereo cable there is a problem within the speaker. There are a lot of things in a powered speaker which, if faulty, can produce unwanted noise and it would have to be opened so that it could be checked to see what is causing the problem
このアンサーは役に立ちましたか?
スコア 7
1件のコメント:
This was super helpful, thank you so much
さんによる
コメントを追加
Hi,
Static sound is often caused by connectivity issues to the Wi-Fi. Make sure that the speaker is within proper range to the nearest router, around 100-150 feet. This will ensure a good connection via Bluetooth, and the static sound should dissolve.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
I tried this, it did not work.
さんによる
コメントを追加
Hi,
Static sound may be caused by dirt and/or dust build-up in the device. Use a condensed air-duster to clear away the dirt/dust from inside the speaker.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
For my sb571 The sound breaks when it is played at high volume what should be done
さんによる
Please troubleshooting
さんによる
コメントを追加
No its a wire shortage or either your wires in the speaker are damaged
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
It's brand new strait out of the box
さんによる
コメントを追加
Hi,
Solved this problem, this is how…
Connected a old Asus mobile charger and humming noise disappeared during charging…this adapter was a 5years old one.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Yana さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 58
今までの合計 88,361
