メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iPhoneの最初のモデル。モデル番号A1203、4GB/8GB/16GBの容量でアルミニウム製の背面を持つ。修理にはかなりのこじ開け作業が必要で、はんだ付けが必要になる場合もある。このページは、iPhone 2Gのトラブルシューティング、修理、サポート情報の検索を目的としている。
Battery life less than expected
My trusty iPhone, just upgraded to iPhone OS 3.1, is losing battery life fast.
I replaced the battery with a new item from iFixit, charged it overnight, and in 6 hours it is down to about 60%.
Is there a way to reset it, especially the energy management (like resetting SMC on a MAC)?
Any suggestions?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
1件のコメント
Hi, Where did you buy the battery? I've an iPhone 1st generation and I'm lookgin for the battery... Help me!
さんによる 共有
コメントを追加
9件の回答
ベストアンサー
well, I have done 2 things - I
reset the phone settings and
switched off push email
so far the phone seems well behaved. Unfortunately I don't know which one of the 2 has fixed it - but I will switch push email back on once I have established the phone battery lasts as it should.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
lasted 24 hours with the battery icon still showing full ... the solution is most likey the reset
さんによる 共有
コメントを追加
最も参考になった回答
Just my advice since I have a 16GB 2nd gen. iPhone. When I upgraded to software v.3 it did not last even a day. I found the clue is to turn off all "push" settings in email. Set everything to "manual" and do it everywhere, also in the submenus. That gave me back my battery life at least.
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
cool - I have my .mac email on push, so I will turn this off and observe. will report back.
さんによる 共有
コメントを追加
Have you tried letting the battery run all the way down until the phone shuts off and then charging for several hours/overnight? That seems to be a common calibration procedure with Li-Ion batteries.
Apologies if that's what you meant by "charged it overnight" but I wasn't clear from the question on whether the battery was empty before you charged it. In any case a full discharge/recharge cycle might help.
Good luck!
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
no worries - yes, the old one was run down a few times, but maybe it needs the NEW one to be run down (silly me not really seeing that, I was so happy to actually change the battery, and it is STILL WORKING ;))
さんによる 共有
I'm not sure whether the run-down calibration procedure is really for the benefit of the Li-Ion cells or whether it's to let the charge circuitry become "acquainted" with the characteristics of the new battery. In any case I'll be looking forward to finding out if this helped!
さんによる 共有
well, it did NOT work.
さんによる 共有
Drat!
さんによる 共有
コメントを追加
Location services is a huge battery hog. Try turning it off (Settings > General) for a couple days and look for improvement.
Do you have Bluetooth on? It shouldn't be the problem, but might as well check. Is your phone jailbroken or unlocked? Those may also make a difference.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Location services were off ...
さんによる 共有
コメントを追加
thanks - well it is jailbroken, and location services are off.
it used to last 4 to 5 days in the sam elocation, same services on etc, and now it is dead in 10 hours.
I even have disabled some stuff that was on before (internet access through the GSM provider)
that is right - dead after 10 hours after being fully charged, and new battery .... something has to be wrong, but WHAT
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Voted down because this isn't an answer. You should add details about the question by editing the question or adding a comment there.
さんによる 共有
very hard to comment or edit if you don't have enough reps to do so!
さんによる 共有
コメントを追加
Are you using the device more? 10 hours does seem pretty quick, but I've never had an iPhone that could last more than about 36 with any real usage.
Did the decrease correlate with the update to OS 3? Did you re-pwn the firmware for the upgrade, or just auto-update in iTunes? I've seen some weird things happening with jailbroken 3.0; if you built your own, you might want to consider reinstalling it.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
thanks - been re jailbroken. My wife's Iphone (bought the same time, updated same time) seem sto worrk better and she if anything is using it more. the 10 hrs is stdby + use = total time!
さんによる 共有
コメントを追加
My iPhone 2g runs out battery empty for 2mins..
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
May be you installed too many programs on your phone, you need to uninstall some programs.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Apple told users that the battery recording function does not affect the battery life itself, but will take a larger hard disk space. Therefore, the proposed user to connect to the iPhone with the computer, the records transferred to your computer. When the iPhone with your computer is set to sync, this process will be automated.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Spikey2 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 37
今までの合計 5,114
