What does the blinking light mean?
I noticed that the green light is blinking. Is something wrong with the Dremel?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Don't worry - The blinking doesn't mean that there is an error. The green LED on the charger indicated that you properly plugged the battery pack into it. While it is charging, it will continue blinking. When charging is complete, the light will stay steady green.
このアンサーは役に立ちましたか?
Sweet I was wondering the same thing, thank you interwebs.
Same here..........
Mine keeps on blinking and when I go to use it, it has no power to operate my Mini Mite
Mine blinks when I first put the battery in..5 min later its steady green and of course it is NOT charged. Waiting to hear back from Dremel.
I have two lighs. one steady red and other is flasing green float. what does float mean
7700/708 battery. green light has been "charging" aka "flashing of 18+ hours and battery is dry as a bone, no charge.
This @#%$#@^ 7700 has LESS than 18 hours of use in 4+ years. Battery is stores away from charger (separate rooms). does the battery just die from being lonely?
このアンサーは役に立ちましたか?
Same issue as @ralph78 and @rroby. Charger LED just keep flashing green. I have two batteries - does the same with both. The flashing seems to be somewhat faster than normal charging indicator. It never goes to steady green (indicating a fully charged battery) and neither battery has any power. I use the dremel infrequently so have always charged a battery before each use. I'm thinking it must be a charger issue rather than a battery problem? Do I need a new charger or have both batteries died?
過去 24時間: 8
過去 7 日: 27
過去 30 日: 118
今までの合計 41,227
1件のコメント
What if it never stops blinking??
Angela Backus さんによる 共有
