Second HDD in optical bay not working properly
Hi,
I have installed a second 1TB HDD in place of the superdrive but it is not working well.
File reads from that HDD, file transfers to and from that HDD all result in a beach ball. If I try to do big transfers the HDD vanishes from the system! I have to reboot to see the HDD again!
Searching online I found this - http://blog.macsales.com/14982-efi-updat...
I thought problem solved. The Apple site with the update also states its for mid 2012 macbook pros - https://support.apple.com/kb/DL1593?loca...
However whenever I try to install the update it states "This update is not for this system". I am not sure but I think this is because I have OSX El Capitan running, rather OSX Lion or Mountain Lion.
I have OSX ML on an external HDD. Should I use it to boot my laptop and then apply this update? Will putting back the drive with El Capitan after the update cause any issues?
Is there something else I can do or should I just get an Intel 320 600 GB SATA II SSD instead for the optibay?
この質問は役に立ちましたか?
6 件のコメント
Can you give us the make and model of your HD's (both the primary & secondary).
Dan さんによる
For now I would hold off buying anything until we can guide you here with what you have now.
Dan さんによる
The main HDD is APPLE HDD HTS545050A7E362 , its 500 GB.
The secondary HDD is HGST HTS721010A9E630 , 1TB Travelstar 7K1000.
I had bought a Samsung 850 EVO 250GB which I intend to use to replace the primary HDD. Using the SSD for the OS/apps and HDD for data.
I don't want to mess with the primary HDD much, keeping it as a backup bootable drive for use if the EVO ever conks off.
Gautam Thakur さんによる
How was the new drive formatted? Have you run Disk Utilities from the main drive on the new one?
mayer さんによる
Yes. It's formatted to HFS+ journaled. I have two partitions, 250GB and 750GB
Gautam Thakur さんによる
1以上のコメントを表示
