メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2009年2月に発売されたAM3ソケットは、941個のピン接点を持つAMDプロセッサ用CPUソケットです。
Monitor not displaying anything because of CPU
My monitor is not displaying anything on screen. There is no fault in monitor, the fault is in the CPU processor, as I already checked my processor on other motherboard, my question is can i repair my processor. There is no damage as I can see on processor. It is clean.
AMD FX-8150.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
4 件のコメント
How do you know it isn't the GPU or video card? What's it in? What does it do? If the CPU works in another machine, it's obviously not the CPU giving the problem, is it? What does an external monitor show?
さんによる
If your processor has no damage ,
if the possible solution is clean your RAM before connect on-board or replace
さんによる
How do I fix my cpu on my computer
さんによる
CPU's can NOT be repaired.
さんによる
コメントを追加
4件の回答
ベストアンサー
mohityenugwar there is nothing you can do. If your processor has failed the only way to get things working, is by replacing the processor.
このアンサーは役に立ちましたか?
スコア 8
コメントを追加
There is no realistic way to repair a processor itself. The only viable solution is to replace it. You should be able to find used Phenom x2/3/4s fairly cheap online.
Update (01/17/2017)
Also, most AMD FX series processors do not include integrated video capabilities. These CPUs were designed for gaming systems with dedicated graphics cards. There is a possibility there is, in fact, nothing wrong with the processor.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Re-read the question ". . . I already checked my processor on other motherboard. . . "
さんによる
コメントを追加
U can change d processor can't b repair
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
It could also be the motherboard. Try the CPU on a different motherboard and see whether you get anything. Vice versa, you could also try a different CPU on the same motherboard. My guess is that most of the time, it's the motherboard.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
さんによる
コメントを追加
回答を追加する
mohityenugwar さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 58
今までの合計 4,015
