メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2013年に発売されたTDK Life on Record A26は、Bluetoothとスピーカーフォン機能を備えた、防水・コンパクトなポータブルスピーカーです。
What does flashing lights mean?
I turn on the hard switch and push the power button, after three seconds the bluetooth and auxiliary buttons flash. Then device turns off and does not work. Is there a way to fix this? It is an error code but I can not find what it means. Any ideas?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
9 件のコメント
please supply error code
さんによる 共有
The error code is the simultaneous three flashes of the auxiliary and bluetooth buttons. I do not know what that signifies but if you are a computer literate you would understand that it is an error code.
さんによる 共有
Hi, I realized it was an error code but thought perhaps a reset might clear it
さんによる 共有
Yeah, I tried the reset again, regardless. Still didn't help.
さんによる 共有
Hi,
Can't find any info regarding error codes, so am trying to eliminate possibilities. All these questions relate to establishing whether there is a problem with the battery and or the charging circuitry of the speaker.
1. What happens when you only connect a charger that is powered on? 2. Does the correct charging light i.e. red or amber show? 3. If red does it eventually change to amber? 4. Does it work properly when fully charged? 5. If not does it work properly when connected to the charger?
If the above do not point to a problem with the power:
Have you tried disconnecting the battery for a short period and then reconnecting it to see if this clears the problem? Here is a link that shows how to unplug the battery http://downloads.imationsupport.com/lor/...
2 part answer
さんによる 共有
4件以上のコメントを表示
コメントを追加
1 件の回答
最も参考になった回答
Hi,
Here is a link that shows how to reset your A26.
http://support.tdkperformance.com/articl...
Hopefully this is of some help.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Tyler Pratt さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 28
今までの合計 1,848
