メインコンテンツにスキップ
The Samsung Galaxy S 4G is an Android 2.2-powered smartphone with a 4-inch AMOLED touchscreen display and 1 GHz processor.
62回答 すべてを表示
switching on and automatically shuting down
my phone is switching on and automatically shuting down
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
ベストアンサー
Hi,
Here is a link that shows how to perform a 'soft' (wipe cache partition) and a 'hard' (master reset with hardware keys) reset on your phone.
Perform the soft reset first and see if it resolves your problem, if not perform a hard reset.
A soft reset does not erase any of your apps or data
Be aware that a hard reset will erase all your downloaded apps and user data. It will restore your phone to a factory default condition. It will be like when you first bought it.
Before you perform a hard reset ensure that the battery is charged.
Do not leave the charger connected when you perform a hard reset.
Remove the SD card (if there is one inserted).
https://support.t-mobile.com/docs/DOC-94...
Be patient, it takes a few minutes.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Hi
I would suggest to find someone to flash new software in to your phone as it seems the old one have crashed.
Hope this help
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
When phone is on hard to use freezes then giving program stopped, process ui, stopped, no sounds, cant eatch videos
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
maidayasin さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 4
今までの合計 110
