switching on and automatically shuting down
my phone is switching on and automatically shuting down
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
Here is a link that shows how to perform a 'soft' (wipe cache partition) and a 'hard' (master reset with hardware keys) reset on your phone.
Perform the soft reset first and see if it resolves your problem, if not perform a hard reset.
A soft reset does not erase any of your apps or data
Be aware that a hard reset will erase all your downloaded apps and user data. It will restore your phone to a factory default condition. It will be like when you first bought it.
Before you perform a hard reset ensure that the battery is charged.
Do not leave the charger connected when you perform a hard reset.
Remove the SD card (if there is one inserted).
https://support.t-mobile.com/docs/DOC-94...
Be patient, it takes a few minutes.
このアンサーは役に立ちましたか?
Hi
I would suggest to find someone to flash new software in to your phone as it seems the old one have crashed.
Hope this help
このアンサーは役に立ちましたか?
When phone is on hard to use freezes then giving program stopped, process ui, stopped, no sounds, cant eatch videos
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 5
過去 30 日: 6
今までの合計 112
