メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Logitech Harmony 650は、Logitechが製造するユニバーサルリモートコントロールです。カラースマートディスプレイを搭載していることで知られています。
My remote keeps resetting its self
My Logitech Harmony keeps resetting itself. I don't know why this keeps happening. What is causing this to happen, and how can I fix it?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
5件の回答
ベストアンサー
The problem could be that your battery connectors are faulty. This is actually a common problem with this specific device. Check to make sure that the batteries are well seated in the remote, and if that doesn't work check to see if the connectors move when you touch them. If they do move then you will either have to repair or replace them. For help in doing so check out the troubleshooting guide.
このアンサーは役に立ちましたか?
スコア 6
2 件のコメント:
It may just be the batteries are flat as well. The remote seems to work fine with the screen lit up but if the batteries are flat and you send some commands, the remote will reset - at least that is just what happened to mine this evening.
さんによる
@Kyle, thanks. Worked after batteries replacment
さんによる
コメントを追加
After trying the above solutions, simply putting in new batteries totally fixed this problem for me.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
To keep the batteries better seated between the contacts, I put a small, narrow piece of foam packaging (1/16-1/8” thick) that’s about the size of two postage stamps over the batteries and gently closed the battery cover over it. The batteries seem much secure as I shake the remote.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Instead of replacing the faulty battery contact thingy, I just wedged a square of tinfoil between the battery and the positive contacts. Voila. Works like a charm.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
How exactly did you do that? Did you have to disassemble the remote? Thanks Jude!
さんによる
i took Jude's idea: folded a small piece of aluminum foil about the size of the top of the AA battery, held it on the (+) connector by wrapping scotch tape around the rim. Seems to have stopped rebooting. A more permanent solution will be to affix the foil inside the remote instead of on the batteries.
さんによる
I thought I had to buy another Remote because it constantly lost its connection with our equipment. Then I tried this fix!
I had the same great result wedging in a piece of folded aluminum foil between each of the batteries and the Remotes battery connector. Now my Remote works great. Thanks Jude for this simple fix!
さんによる
コメントを追加
I created a small hook from a paper clip. Gave a little tug on each of the connectors inside the device.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Austin K さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 11
過去 30 日: 38
今までの合計 40,997
