Eyepiece is not working.
One of the lens components inside the eyepiece is out of place after a bump. Can it be fixed or must the eyepiece be replaced?
Please see @flyingdutchman 's answer to this question: How to get access to fix the optical view finder lens?
You will have access to your viewfinder, and will be able to assess whether it needs replacing or just popping a lens back in.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 6
過去 30 日: 24
今までの合計 1,148
@jlaurent, I have the same situation, and just asked if anybody knew whether the top cover guide can give us access to the lens compartment.
If you are interested, it's here: How to get access to fix the optical view finder lens?
If you've fixed it or had it fixed, how did you do it? Thanks for sharing
dauffret さんによる
@jlaurent, I was able to fix my viewfinder, with advice from @flyingdutchman, you can see his answer here: How to get access to fix the optical view finder lens?.
It is the answer I have accepted. Hope it helps!
dauffret さんによる
