Why it always show no service?
My Honor 4x always show No service. I alreadr checked with different companys sim, but the problemm is still same. Showing no service. Please help me to resolve this issue.
[Email Redacted]
Yes previously it was working fine, but once its display and touch had broken due to feldown. So I changed the screen. But after changing the display network is not coming. Shopkeeper said its software problem. I have to go to service centre.
このアンサーは役に立ちましたか?
Signal Strength ? then network manual
try to imei change then try network show
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 2
過去 30 日: 11
今までの合計 14,813
10 件のコメント
Hi,
1.Has the phone ever worked using a SIM card? 2. Does it say no signal or no SIM card found? 3. Have you tried to factory reset the phone?
jayeff さんによる
hi my honor 4x shows no service...center said network IC problem..u have to change motherboard costing 8000 rupees...is any other way to repair Network IC or motherboard...8k is big amt nowdays u get phone in 8-10k...pls advice
Prashant Oza さんによる
I also having the same problem. Pl's tell service advisor's to recover my mobile from this problem
rakesh 007 さんによる
same problem i also having trouble after changing my honor holly 2 plus
Gnanavel r さんによる
I also have the same problem. My Huawei honor 4x can't detect my simcard. I already tried a lot a sim but still the same. Have the sim icon on the top with exclamation point. Will you please help me with this ?
Akachan Jimenez さんによる
5件以上のコメントを表示
