メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP Color LaserJet 2600nは、Hewlett-Packard社製のカラーレーザープリンターです。
paper feed issue on printer
When printing, just as the paper begins to exit into the tray, the paper jams. It wrinkles the leading edge of the paper. Took it to local repair shop and they thought it was a fuzing issue, but couldn't say for sure less than $118. charge.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
The fuser is the likely suspect and it is possible that the roller is bad. If the printer has had labels put through it then the likely issue is the glue has got onto the roller hence the jamming. Try removing the fuser and clean the roller with an alcohol based cleaner which should not leave any residue. If the roller is damaged it can be replaced but you would need to obtain a service manual (worthwhile) to enable dismantling. There are going to be you tube videos on aspects of fixing a fuser assembly.
Hope that helps find a solution.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Joey Pace さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 10
今までの合計 545
