メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Why does vertical line appear on documents using ADF as source
If I copy from the flatbed everything works fine. However if I copy or scan using the ADF, then a black vertical line appears down the center of the output document.
I wonder if there is dust or dirt in the ADF causing the line to appear, if so where can I find instructions for opening and cleaning ADF.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 11
9 件のコメント
Didnt work. Cleaned the entire ADF area and nothing helped
さんによる
Cleaning didnt work. The line is very straight, top to bottom, not smudged like dirt. Almost like a scratch.
さんによる
cleaning did not work. is there any other solution
さんによる
I have no narrow strip of glass on my scanner
さんによる
IT WORKED! Cleaned the small space of my Epson WF-3530 with alcohol and cotton ball. My documents (scanned, copied, faxed) have had red streaks for over 2 years or so.
I'm excited the problem is solved and was free to resolve. :)
さんによる
4件以上のコメントを表示
コメントを追加
4件の回答
ベストアンサー
Hi,
Here is a link to the User Manual that shows how to clean the ADF area and rollers. Scroll down to Cleaning and Transporting your Product, click to open then click on Cleaning your Product
https://files.support.epson.com/docid/cp...
このアンサーは役に立ちましたか?
スコア 16
14 件のコメント:
clean the small glass. worked!
さんによる
Cleaning the small glass worked. Thank you
さんによる
This is so cool!! thank you!!!
さんによる
yes cleaning glass did the trick . thanks
さんによる
Cleaning the narrow strip of glass on the left worked - also vacuumed the left side to remove dust. - Thanks
さんによる
9件以上のコメントを表示
コメントを追加
This problem occurred with my Epson WP-4530 when using the ADF to scan. Epson manual says to avoid chemical when cleaning the ADF, but I could only remove the lines by using alcohol. Dry cleanig wold not work, but alcohol worked great!
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thank you, thank you! I removed the lines using rubbing alcohol and a microfibre cloth on the glass, the clear plastic on the ADF, and all around the clear plastic on the ADF. Clear as a bell now!!
さんによる
コメントを追加
It took spraying condensed air on the rollers to clear up my problem.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Cleaned small glass panel on left. Small ink blot removed with alcohol. Removed line on feeder and feeder scan copies.
さんによる
コメントを追加
Tried wiping the ‘small glass panel on left’ with a dry cloth but this didn’t help. Went at it again with a cloth dampened with alcohol screen cleaner and problem solved.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Like some others who've posted, I inspected the small glass panel...subtle amounts of schmutz on it. Took some Windex and elbow grease to remove it. BUT......the effort was worth it......the two vertical black streaks on all my ADF-scanned documents were GONE !
Thanks for the suggestion.
さんによる
After using microfiber with alcohol it's gone.
さんによる
コメントを追加
回答を追加する
rglee46 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 57
今までの合計 40,921
