メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Dell Precision M4600は、強力な処理能力を備えたDell Mobile Workstationsシリーズの15.6インチラップトップであり、2011年から2013年にかけてDell Computersより発売されました。
Screen Flickering when start from Cold
My Laptop Screen flickers with fuzzy pixels when it start from cold and still flickering until it warm up then i should close the lid and open it again to disappear and back to normal state.i attached external monitor to check if this from graphics card but external monitor worked fine without any problem.i want to know if this problem from the screen itself or problem with the motherboard?
this video show how it`s flickering.it`s not my laptop but just for clairfying the problem.
https://www.youtube.com/watch?v=ctHn8P-2...
Thanks in Advance.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
ベストアンサー
hi ,
I disabled optimus nvidia option from bios and this solved my problem.thanks for your help :)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
最も参考になった回答
mahmoud eldeep since it displays properly on an external monitor, I'd exclude the motherboard/GPU. It is easily possible that you are having issues with the LCD. I'd start there.
このアンサーは役に立ちましたか?
スコア 2
9 件のコメント:
Thanks for your fast reply. but is there any explanation for this phenom? is cold can effect on the screen and make it flickering like this?
さんによる 共有
Yes it can. coils,caps and resistor as well as transformers can have cold solder joints that may close during warm up.
さんによる 共有
I`ll replace my screen and feed you back with the results. Thanks Man
さんによる 共有
I have another Dell Latitude E5520 with Screen of 15.6” HD (1366x768) Anti-Glare LED. I exchanged the two LCD and my screen works fine till now on latitude without any flickering from startup and latitude screen works fine too on my laptop without flickering at startup too till now.my screen is 15.6" 1920x1080 HD Ultra Sharp Anti-Glare LED.what may cause this problem??!
さんによる 共有
the problem not from the monitor as i replaced it with another low resolution one (1366*768) and it did not show up the problem.i think it`s something related to power input from graphics card to the monitor as FHD monitor consumes alot of power than the HD monitors.but i still can`t determine which part i should replace.
さんによる 共有
4件以上のコメントを表示
コメントを追加
https://okadtech.com/dell-laptop-screen-...
Hope this will help you
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
mahmoud eldeep さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 14
過去 30 日: 38
今までの合計 9,343
