メインコンテンツにスキップ
2011年初期のモデル。モデル番号はA1278 / 2.3 GHz i5 or 2.7 GHz i7 プロセッサー。
782回答 すべてを表示
wifi problem connection: antenna cable and airport
i have a wifi problem connection: my macbook connects only if i lower the screen.
the apple assistance says there is a problem with the antenna cables in the display and with airport card. and says that is necessary to replace display and airport/bluetooth card with thermal pad.
do you have any alternative advice?
i find some guide for replace the airport card but i don't know how to fix the problem with the cable in the display...
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
This app will help in checking your WiFi services: WiFi Explorer. With it, see if you note a difference as you move the lid using a second display to watch things. Just to verify what you noted.
Is your bottom cover dented at all? If it is you may have a short or a damaged ribbon cable.
With the bottom cover removed, carefully remove the EMI foam from the AirPort card. Is the signal better?
Does the antenna wires look damaged or not properly connected? Review this IFIXIT guide: MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Board Replacement
The antenna board with new leads is replaceable, its held in the clutch cover. Follow this IFIXIT guide: MacBook Pro 13" Unibody Mid 2010 AirPort Antenna Replacement.
Here is the needed part: MacBook Pro Unibody Airport Antenna.
I would guess the antenna leads are damaged given your symptoms, but I've also seen odd things with the AirPort board and the ribbon cable.
MacBook Pro 13" Unibody Early 2011 AirPort/Bluetoothボードの画像
ガイド
MacBook Pro 13" Unibody Early 2011 AirPort/Bluetoothボードの交換
難易度:
中レベル
20 - 30 minutes
MacBook Pro 13" Unibody Mid 2010 AirPortアンテナの画像
ガイド
MacBook Pro 13" Unibody Mid 2010 AirPortアンテナの交換
難易度:
難しい
30 minutes - 1 hour
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
vickie さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 706
