メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Ulefone製Androidスマートフォンのサポート情報。
Guide for Ulefone Paris Touch screen replacement
Hy All!
I broke my Ulefone Paris screen and I'd like to replace it.
I have experience in screen replacement (ZTE, Jiayu, THL, Samsung, Ipod touch etc)
Do you know any problems or traps about the screen replacement of Ulefone Paris?
Or has someone experience or guide about Ulefone Paris screen replacement?
Thank you in advance.
BR
Norbert
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 5
13 件のコメント
Its much easier. We did watch the youtube video. Changing a broken screen is much easier! don't disassemble your phone! Just apply heat to the screen to loosen the sticky mass the screen is sticked to the frame. Use the plastic part thats comes with the new screen together with the sucking device and carefully loosen the glass screen. Carefully loosen the small multiconnector that is attached to the flat-cable underneath the screen. And hey presto your broken screen is there without the use of any screwdriver. then use the old plastic sticker and attach that to the new screen(on the metal part. You will need some new gluet to stick the new screen to the frame. Thats all. No desoldering at all!
さんによる
What do you mean by plastic sticker? @jwhen46
さんによる
I must make the full exchange and touch lcd. the spare room is a complete block (you have a photo or video or detail drawing) thank you
さんによる
There is a sort of thin black ulefone isolation sticker on the metal plate that is attached to the glass screen. I peeled that off and did put that on the new replacement screen,
さんによる
Read the manual underneath by robertpei. Thats what I did too. Just use the old stickers where possible!
Don't make the mistake I made by disassembling the whole phone and desoldering the tiny flatcable attached to the on/off volume assembly. Hereby destroying this tiny bit. Damaged that and had to replace that by a new one too. Do not desolder anything at all. That is absolutely not necessary!!
さんによる
8件以上のコメントを表示
コメントを追加
5件の回答
ベストアンサー
Hi,
Here is a link that shows the dis-assembly of a Ulefone Paris. Although it doesn't get as far as the screen/digitizer dis-assembly it may be of some help to you.
https://www.youtube.com/watch?v=MmYv98M5...
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
This one is better:
ULEFONE PARIS - TOUCH SCREEN REPLACEMENT - https://youtu.be/f77QGIrbSEo
さんによる
コメントを追加
最も参考になった回答
Hy All,
I replaced my broken screen on my Ulefone Paris at last :)
OMG, it is easy as pie. Don't even need to disassemble the phone. Warranty tapes are intact!!!
Step by step:
- turn of phone, remove battery
- remove black plastic film under battery
- remove yellow tape from ribbon cable, disconnect screen ribbon cable from connector
- apply heat on screen
- carefully disassemble screen from phone (only the glass, plastic frame is part of phone base)
- move tapes from old screen to new if you like
- assemble new screen with phone using double sided tape
- connect ribbon cable to connector under battery, put yellow tape back to secure it
- put black plastic film back, insert battery and cover
- turn on and enjoy :)
このアンサーは役に立ちましたか?
スコア 4
4 件のコメント:
Congratulations @norbertpeli that is awesome! I still havent replaced mine. Did you only change the glass or both glass + lcd? Did you record it/ take any pics? Did you apply heat with a hairdrier?
I will try it today we'll see how it goes!
Thanks for telling us!
さんによる
Hi, how did you removed the "black plastic film under battery" ?
さんによる
さんによる
Javier, your video in really great and self-explained !! Well done and thanks again !
さんによる
コメントを追加
There is only one ribbon laying underneath the screen. The screen has only one connector. Those two have to be connected. That should be connected. You might ask the ulefone service department like i did. Very friendly and helpful people there! (service@ulefone.com) They did send me this after I asked them for a specific part I damaged:
Hello, you can buy it from etotalk: http://www.etotalk.com/ulefone-paris-sid... and you can choose the shipping method.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
For replace the only glass??? The display and touchscreen respond very well but the glass is broke. Solution?
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Same thing, you can't replace only the glass
さんによる
コメントを追加
Screen is very fragile isn't it, broke mine too (first time I have ever damaged a phone screen).
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
same problem...i saw the video but i'm not ready to replace the lcd at this time.has anyone manage to do it?
さんによる
コメントを追加
回答を追加する
norbertpeli さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 24
今までの合計 9,188
