メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
NeuTab N7 Proは、フロントカメラとリアカメラ、7インチディスプレイを搭載し、Android KitKatで動作するタブレットです。
Device will not charge.
I received the device in early August and in December it stopped charging. We checked the charging cord and tried other cords but nothing happens when it is plugged in.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
1件のコメント:
try wiggling the charge cord around when its plugged in . Does the port move at all or does it seem solid check in the port for fuzz or dirt sometimes stuff gets into the port and stops the process
さんによる 共有
コメントを追加
2件の回答
At the same it depends on your device, but assuming its a cellphone... probably the charging port its self needs to be replaced, or the battery.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
It is a tablet sold under the brand name Neutab N7 Pro. (7" Quad Core Google Android 4.4 KitKat) purchased from Amazon.com and received in early August 2015. It was in use less than 5 months when it stopped charging/working.
さんによる 共有
Do you connect your tablet using Turbo Charger? if that makes sense
さんによる 共有
コメントを追加
Same thing happened to both my grandsons' N7S Pros. I had to open the tablet (see Youtube for instructions) and carefully inspect the underside of the circuit board where the charging jack is mounted. The center pin had broken loose and needed to be carefully resoldered to the board. This procedure may be beyond the capabilities of many users. You'll need soldering skills and proper tools. If you're not comfortable with this procedure it's probably best to contact a repair center.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Marion Davis さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 24
今までの合計 1,316
