メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Game Boyは1989年4月21日に日本で発売され、続いて1989年7月31日に北米、そして1990年9月28日にヨーロッパで発売されました。大型のグレーのケースとモデル番号DMG-01が特徴です。
My start button or a button wont work
When i loaded tetris i got the nintendo ding and it started but when i tryed to start the game it wouldn't i don't know if my game is broken or my gameboy.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
3 件のコメント
where can i send my gameboy for repair?
さんによる
i will pay for the repair.
さんによる
MY EMAIL ADDRESS IS: butchnthelma@gmail.com
さんによる
コメントを追加
4件の回答
最も参考になった回答
Hello Nick, sorry about the horribly late response, you know how these sites are, sometimes you get a response within a day, sometimes in over 8 years...
For this I am assuming you have an original GBA or older, if this Gameboy is an SP or newer, I cant help you.
This is a relatively easy fix, the most common reason for this problem is that the conductive pads under the silicon pieces have become coated with... stuff? (I have no idea what the heck it is.)
> Take out the six screws on the back, two are under the batteries. They are usually tri-wing, but I have seen Original Gameboys have Phillips.
> The ribbon cable connects the two halves together. Be very cautious as if you tear this ribbon cable in any way, then congrats, you broke your screen. To remove on an original Gameboy ribbon cable, get a good grip on it and pull it out of its housing. If this is a Gameboy Pocket or newer, lift off the back shell. You will see the workings of the Gameboy. push up the two tabs on the sides of the ribbon cable, take out the three Philips screws, disconnect the ribbon cable and lift up the board.
> (Only follow this step if you have an original Gameboy) Take out the TEN (bit of an overkill there really...) Philips screws on the screen half of the board, and lift off the board. The screen is attached to this board, so be careful.
> Last step! remove the silicon piece of the button that is giving you trouble, and grab a piece of paper. Push the silicon piece and you should see the conductive pad stuck to the inside, take it and rub it on the paper, you should see a pencil-like mark appear on the paper. This cleans the pad. You can now reassemble the Gameboy and test it out.
My god that took ages to type...
このアンサーは役に立ちましたか?
スコア 5
2 件のコメント:
oh my lord thank you for this! my original GBC had issues with its start button for about a decade now and this finally fixed it! did have to get some special tools to get the triwing bits but i had no idea what the actual issue would be.
さんによる
Worked perfectly, you're a childhood saver!
さんによる
コメントを追加
Open it and check the point, where the Start-button press on the logic-board.
Maybe try another game, if the start-button works on another game, the Cardridge is damaged.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
A ver si os sirve este vídeo
https://youtu.be/G9P1tYU3muM
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My start button does not work
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Nicolas Leonardo さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 47
今までの合計 18,580
