メインコンテンツにスキップ
Digital Pocket Memo with slide switch operation.
5回答 すべてを表示
Why is the screen on my DPM frozen?
Since I dropped my DPM from about five inches, the screen is frozen. When I turn it off and on the device starts with the same screen. I switched the BA-slider and could listen to my recordings, so I believe the problem is caused by the display, right?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
My DPM8000 just froze up with lit screen as I was preparing to use it to transcribe
さんによる
コメントを追加
1 件の回答
As you already figured out there is not much of an uncertainty that the source of your problem is the display. First of all you should check the plug connection between display and logic board. If the connection just came loose or undone you simply need to plug it back in. Otherwise you will have to purchase an exchange display. We recommend to have an additional look at the Troubleshooting Page for any other causes.
For disassembling and replacing please refer to the provided guides.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ecodesign TU Wien さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 10
今までの合計 749
