cant charge my table
I cant charge my table, do your company sell one that will fit my device
the recver end of the charger is pushed back in not allowing the power cable to make contack . it needs to be pused back in place to make contack agend.
このアンサーは役に立ちましたか?
How do you pull the receiver end back out
How do you pull the charger piece back because mine is pushed back
How do I pull back out or where can I send for repair
do you have to open in up
My tablet will not charge. The end of the charger will not connect to tablet?
このアンサーは役に立ちましたか?
I am having the same problem! What is the answer?
I would like to have this uniy replaced there is something wrong this is pnly about the twenty time this has happened i am tired of this.
このアンサーは役に立ちましたか?
tablet dose not response or turn on or off
このアンサーは役に立ちましたか?
My charger wobbles when it is connected to the tablet and the charger end does not go in completely. It won't charge. What gives?
過去 24時間: 0
過去 7 日: 6
過去 30 日: 20
今までの合計 1,721
10 件のコメント
Mine will not charge, it's only 2 months old
Paul Case さんによる
Also when I try to turn it on a battery symbol with a triangle in it appears
Paul Case さんによる
I have the exact problem, is there a solution? Besides buying a new one.
Yvonne Cowan さんによる
I am also having this problem, getting very frustrating!
lulalor68 さんによる
Mine and my daughters will not turn on either and both are only 3 months old!
Carlo Stokes さんによる
5件以上のコメントを表示
