メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2014年11月1日に発売されたAndroid 4.4.2搭載スマートフォン。
How do I bypass pattern code
How do i bypass the screen pattern lock
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 25
9 件のコメント
Blu studio 7.0 asked for pin code
i used 10 1s but still could not log in
please how do i bypass to access my information
さんによる 共有
How to unlock pattern lock screen
さんによる 共有
Someone set a password on my blue bold phone and I'm unable to use my phone. How do I bypass the password without factory reset and without losing any data?
さんによる 共有
i am here asking a question why is one being ask to me
さんによる 共有
Hello, I've tried all the videos but they start moving so fast instead of explaining while they're going through it I can't keep up every if I try to rewind and pause, it still is ridiculously fast. Having a brain tumor makes it worse. Is there anyone that will be willing to help me online, through a text, or email, PLEASE?? Thank you.
さんによる 共有
4件以上のコメントを表示
コメントを追加
3件の回答
最も参考になった回答
Android comes with protection features like Pattern lock or Password lock to prevent your smart-phone from unauthorized use. But if the owner of the phone is forgot Pattern lock or PIN, then problem arises. I am suggesting you some tricks to recover your lock-
Visit at google.com/android/devicemanager on your phone or computer and sign-in using your g-mail that you used on your lock phone. Under ADM, select the device you want to unlock and then select “Lock”. Then a new window appears and asked for password, you can enter a temporary password into this window and click on “Lock” button. Now you got a confirmation tab window having the buttons Lock, Ring and Erase. Now you can see a password field on your phone, you should enter that temporary password and your phone would be unlocked. Now go to the phone settings and disable the temporary password and change your pattern lock that is easy to remember but typical to guess by others.
If above procedure is not working then try this one-
If you don’t remember your password then enter a wrong password or pattern lock 5 times, a window appears. You should select “Forgot Password”/”Forgot Pattern” option in this window so you would able to open a Google login or backup PIN. Enter either your g-mail login or backup PIN and then You would be able to unlock your phone.
このアンサーは役に立ちましたか?
スコア 6
3 件のコメント:
How do I bypass a password on a vivo 5 mini?
さんによる 共有
How do i bypass pattern lock
さんによる 共有
How do I unlock my screen passcode
さんによる 共有
コメントを追加
How do break pattern code on a Android blu
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Factory reset it
さんによる 共有
how do I break in my blur phone with out factory resetting phone
さんによる 共有
コメントを追加
Factory reset the phone, it should be ready to be switched
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
jgh25041963 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 59
今までの合計 20,254
