メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Sonyの15.5インチコンバーチブル型タッチスクリーンノートPC。
Flip 15 will not boot - Error code: 0xc000000f
I downgraded from Windows 10 to 8.1 the other day and after rebooting I got the error message below.
'Recovery
Your PC needs to be repaired
The boot configuration date for your PC is missing or contains errors
File \EFI\Microsoft\Boot\BCD
I have tried 8.1 installation media via USB as my Vaio doesn't have an optical drive and each time I got in to it I get that blue screen and when I press refresh or re-install it says "The drive where Windows is installed is locked.Unlock the drive and try again."
What can I do to resolve this? I have tried check disk, tried bootrec but nothing works, any help would be gratefully appreciated.
(If the hard drive needs replacing, what would I need and where do I get it from?)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Check here this might help: http://www.tomsguide.com/forum/id-185218...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Pointers to be focus when you encounter this error.
Corrupt boot sector due to power outages, virus/malware infection.Damaged hard disk due to power outages.
Corrupt system files due to improper shutdown and/or power outage.
Damaged Hardware
Check this website for Solutions
https://www.errorsolutions.tech/error/er...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Kian O'Donoghue さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 9
過去 30 日: 27
今までの合計 1,199
