メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Nikon Coolpix L820は、16メガピクセルの乾電池式デジタルカメラです。
Why will it not load a memory card?
When I try to load a memory card screen comes up error other than that it works fine.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
Hi,
Can you read the card in a PC (if you have a card reader that is)? If you cannot read it in a PC the card may be faulty. Try another card, first in the PC (to make sure it works) then in the camera.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Hi, I have a L820 Coolpix and it comes up about it can't use my Photo Card ,and I have tried a couple different cards and still doesn't work ?
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Hi,
What error message are you receiving?
Are the cards being detected?
Did you try formatting the card in the camera?
さんによる
I have tried a couple different cards that are designated to use for the L820 and it still comes up cannot read ? I have inserted the card in my computer and earlier I had downloaded some software to format the card ,but is there a certain way / steps to make it format ?
さんによる
Hi @curt56 ,
I realize that you said that you tried "cards that are designated to use for the L820" Just verifying that the cards you are trying are one of the following types and sizes:
1. SD card max 2GB
2. SDHC card max 32GB
3. SDXC card max either 64GB or 128GB depending on manufacturer.
You don't need special software to format a SD/SDHC/SDXC card in a PC. The PC can already do it.
Here is a link that shows how to do it.
http://www.wikihow.com/Format-an-SD-Card
さんによる
コメントを追加
回答を追加する
Bryan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 17
今までの合計 2,077
