メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Micromax Canvas 2 Plus A110Qは、2013年5月にMicromax Mobileから発売されたデュアルSIM対応のAndroidスマートフォンです。
facing OS system issue
I have a Micromax A110Q Canvas 2 Plus phone whenever I start the phone the canvas word comes on the screen as if it is starting but it gets stuck to that only & my phone doesn't start. The display remains the same i.e. canvas written on the screen. nothing happens after this.
Kindly Help.
Regards,
Ratan Singh.
singh.ratan012@gmail.com
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
I have done the same but nothing changes still whenever I switch on my phone screen comes p by writing canvas on it & after that it gets stuck nothing happens later to this.
さんによる
Hi,
I found this link which may be of interest to you. http://forum.droidarena.in/Thread-How-to... First he states that you press 3 keys (power + vol up + vol down) to hard reset. Different to what I have found (and you as well) elsewhere. Maybe you could try that before deciding IF you want to try his other option.
さんによる
コメントを追加
1 件の回答
ベストアンサー
Hi,
You need to hard reset your phone.
Before you do this make sure that the battery is fully charged.
Warning : A hard reset will restore your phone to factory default. You will lose all downloaded apps and user data!
To perform a hard reset do the following:
1.Turn off your phone
2. Press and hold the Volume Up + Power button (both together) until you see Recovery mode.
3. Release both buttons.
4. Select option "wipe data/factory reset" from the menu.
(To scroll options use Volume buttons, and to confirm press Volume Up key for 3 seconds).
5. Then confirm "yes" by Volume Up.
6. In the end accept (confirm with Volume Up key) operation "reboot system now"
The phone should now reset, be patient it takes a few minutes.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Rats さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 13
今までの合計 347
