How do I upgrade my RAM?
I am looking to put some better RAM into my laptop. How would I go about doing this?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
To upgrade your RAM you will need to remove your current RAM and insert your new one. The link attached shows you how to access your RAM through the back of your laptop. Asus X555LA-SI305041 RAMの交換
このアンサーは役に立ちましたか?
Ram is 1.35v or 1.5v ?
Hi @none1986,
According to both Crucial and Kingston RAM advisor system for Asus X555LA it is 1.35V.
how many slots for RAM have this laptop ?
このアンサーは役に立ちましたか?
Laptop has only 1 slot for ram. And one is inbuilt
Hey, to UPGRADE the RAM you just add or replace the RAM in the side slot in your guide, however if you need to REPLACE the RAM, one is built in and soldered so that one cannot be replace by the end-user. The one in the expansion bay though, can be.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 5
過去 30 日: 22
今までの合計 14,647
