Why does my touch screen not respond?
I can turn my phone on but when I try to use the touch screen it is unresponsive and I cannot access any of those functions.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Try restarting your phone, it might just need to reboot (turn your phone off then on again).
If flickering or faulty remove the battery and place in hot dry area as the humidity may be affecting the screen (BE CAREFUL to not overheat the phone it doesn’t need a lot of heat).
If this doesn’t work or the phone is cracked see the guide on replacing the screen itself as a solution.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 8
今までの合計 269
