メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
GoogleがデザインしLGが製造した第6世代のAndroidスマートフォンです。モデル番号はLG-H790。2015年10月発売。
Rattling noise inside phone?
Is there anything in the 5X that should or could rattle? It seems to be near the camera. I have read others complaining about this as well. I also discovered that the nexus 5 rattles in the same area. You will hear it if you gently shake the phone near your ear. Thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
3件の回答
最も参考になった回答
I have the same problem and I found this thread @ xda-devs
Quoting the author:
'''SOLVED! - I spoke to Google support and they said that the rattling noise comes from the sim tray.
There is a tiny lever which you push with the sim pin to remove the sim tray, and that lever is what rattles against the frame. Providing that your 5X works as it should, that's the rattle.'''
I wouldn't worry about it.
Best of luck!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I have this same problem, but I don't notice anything defective other than that, so I, personally, wouldn't be worried about it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
It's probably the camera lens assembly, i've heard something similar on the Nexus 4 and there were never any problems.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Erg4Life さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 17
今までの合計 3,739
