メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Lenovo製の14インチビジネスノートパソコン、Lenovo ThinkPad T430のガイドおよび修理情報。
Power button LED Blinks when I press power button.
Lenovo T430. Tried following steps, No luck. Refer to my Video here.
  • Try charging the Battery to Full
  • Remove Battery and tried booting it with Power directly.
  • Changed the Keyboard.
  • Removed the Bios Battery and tried to switch on.
  • Removed the RAM and tried to switch On.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
6 件のコメント
Is there a pattern to the blinking?
さんによる
No It just lits up and turns off. I dont think it is a pattern.
さんによる
is there one or two sticks of ram
さんによる
Do you get any fan sounds? Do you hear the hard drive spin up at all
さんによる
yes i hear a fan sound, it comes and goes off (the sound)
さんによる
1以上のコメントを表示
コメントを追加
2件の回答
ベストアンサー
Try removing one stick of ram if you have two and test one stick at a time in each of the two ram slots. Then test the second stick of ram in both ram slots this will tell you if you have bad ram or a bad ram slot. if it still doesn't work you need to consider getting out a multi meter and tearing open your computer and testing the circuit board starting at the power outlet and working into the board
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
I tried the RAM swaps , no change. Also Fan wont turn on. I am not familiar with electronic circuits.
さんによる
Even now 2021 i have that problem on my Lenovo All-in-One Computer IdeaCentre 300-23ISU (F0BY0041US) Intel Core i3 6th Gen 6100U (2.30 GHz) 8 GB DDR4 1 TB HDD 23" Touchscreen Windows 10 PRO 64-Bit
さんによる
コメントを追加
I have a T430 with the same issue. LEDs (power Fn F3 ) are blinks one but the laptop does not turn on.
I triedtoclean the connections, remove the batteries....no change.
Once i removed the RAM and the unit booted up.
So the issue is the following : it works with no RAM, but it does not work with installed RAM.
The problem is the same with the old and a brand new RAM also.
Any idea?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
ksenthilbeit さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 12
今までの合計 31,282
