no sound with text message alert
Why won't my phone sound with text and message alerts?
It rings fine
この質問は役に立ちましたか?
It rings fine
この質問は役に立ちましたか?
Hi,
To change the incoming message tone go to:
Menu > Settings > arrow right to Profiles > Edit > Message Tone
There are a lot of other personalisations that you can change in Profiles > Edit e.g. Voicecall ringtone, Silent, Keypad volume, Keypad sounds, Ringing Type
Hi @Vern Smith,
I cannot find a T93 listed on the ZTE website, but here are the procedures for a T930 and a T90.
As you can see they are virtually the same and are similar to the T95.
Perhaps arrow right means to swipe right.
T930
Click on image to enlarge it for better viewing
T90
このアンサーは役に立ちましたか?
Hi @ Vern Smith,
To personalize your Message notifications:
Open the Message app, then tap the Options soft key ( usually the right hand side key of the 3 soft keys below the screen) then select Settings > Notifications then choose which options you wish to enable, disable and alter.
このアンサーは役に立ちましたか?
done that it works when I choose the tune but when I text from another phone no tune but the text comes through
Hi,
Do you get a notification at the top of the screen when a message comes in? Have you checked in Menu > Settings > Sound to ensure that the volume level for Notifications is set loud enough
I have no arrow right to profiles>edit>message tone I use a t93 phone.
sorry mate it a t83 telstra dave phone
yes, volume set as high as it will go
Try this:
Settings>Apps>Messaging and make sure “Show silently” is not turned on. This worked for the same issue on the ZTE Z835. I hope that helps you and any others who may have this same issue.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 17
今までの合計 17,951
3 件のコメント
No did not workI will take it to telstra store A big thank you for all your help. I am a fireman and all fire alerts come in a text form,as to why I need ring tone
Vern Smith さんによる
very help full
Vern Smith さんによる
A fireman turning out by phone ? You mean your in the bush fire brigade , not a professional firefighter.
John Vandenberg さんによる
