Change default font in phone
hye.im using asus zenfone go, android 5.1 and i cannot download fonts from any website. so i wanna request u..can asus change their default fonts by using helvetica neue fonts for whole system in phone?tq
yes.no customized fonts. too boring and this make me feel not happy for buy this phone
このアンサーは役に立ちましたか?
izznur ,
You can change the default font on your phone.
Step 1 : You should have to root you phone (Kingo root tool is one of easy way to root your phone ( Note : Rooting may cause to void you warranty of device)
Step 2 : Backup existing fonts : Use play store app to backup fonts
Step 3 : Install any font you want to root directory named as Fonts : you can use Font install app on playstore
このアンサーは役に立ちましたか?
Another way to change your fonts
No root
Download this app "iFont" in Google play
And done
*follow the instruction in app
このアンサーは役に立ちましたか?
Doesn't work either
過去 24時間: 0
過去 7 日: 5
過去 30 日: 13
今までの合計 6,565
1件のコメント
I have the same issue. There is no customized system font for zenfone go. That makes it a bit boring. Only the app launcher has.
Amel Wan さんによる
