メインコンテンツにスキップ
2010年4月発売。2.4, 2.53 GHz Core i5 or 2.66, 2.8 GHz Core i7プロセッサ
590回答 すべてを表示
Battery does not charge but power source works
After a tumble from the top of a chair to the floor, MacBook Pro seemed to be okay. However later noticed that the battery was not charging. The power indicator said that it was charging, but the battery charge did not change (or noticeably).
Left plugged in over night the battery went from ~48% to 64% charge. After rebooting the computer the battery will not charge at all. The power connects fine and [so far] everything else seems to functioning properly. I reset the SMC for what it's worth.
The impact was on the corner of the bottom case, the same corner as the right hand rest area. That corner of the case is visually impacted.
Does this sound like an issue of a connection being disrupted or something more serious?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
2 件のコメント
Does the laptop work when it is unplugged? Just trying to determine if the battery is connected to the logic board.
さんによる
If it wasn't then it just wouldn't power on.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
First try another charger, or try the charger in another computer, if it works or another charger produces the same results, then this coupled with the visible damage points to needing a new DC-in board. Here's the install guide.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
+ agreed
さんによる
Just got it back from Apple - they apparently tried replacing the battery, mag-connector, and "battery board" to no avail, suggesting it was damage to the logic board itself. Also realized the keyboard backlighting no longer works. The battery *will* charge but extremely slowly, and so far has peaked out at 75% or so.
さんによる
The repair they made was BS. Call them and send it in explaining you don't trust the service center any more.
さんによる
コメントを追加
回答を追加する
bennylope さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 3,231
