Battery does not charge but power source works
After a tumble from the top of a chair to the floor, MacBook Pro seemed to be okay. However later noticed that the battery was not charging. The power indicator said that it was charging, but the battery charge did not change (or noticeably).
Left plugged in over night the battery went from ~48% to 64% charge. After rebooting the computer the battery will not charge at all. The power connects fine and [so far] everything else seems to functioning properly. I reset the SMC for what it's worth.
The impact was on the corner of the bottom case, the same corner as the right hand rest area. That corner of the case is visually impacted.
Does this sound like an issue of a connection being disrupted or something more serious?
2 件のコメント
Does the laptop work when it is unplugged? Just trying to determine if the battery is connected to the logic board.
Robert Ciaccio さんによる
If it wasn't then it just wouldn't power on.
rab777hp さんによる
