メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
1999年から2004年にかけて生産された、北米向け第2世代Honda Odysseyの修理ガイドと修理情報。
What is the code for the navigation system?
my battery went dead and I need to reboot the navigation system with a number code, but I don't have a manual or know the previous owners code.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
1 件の回答
ベストアンサー
According to honda_guy on this forum:
"Each system has its own unique activation code.the first place to check is inside your glove box. You are looking for a white adhesive tag that is about 1" long and 0.5 inch high. It should have 4 digit code on it. Most of the time the dealers stick the tag on the inside wall of the glove box. That four digit code is the NAVI activation code.If you bought the car new then your dealer should have the code on file. If you call them they should be able to look it uplI assume you looked through the paperwork and that you couldn't find the white "credit card" that has the theft codes on it. Sometimes the dealers write the number on the inside of the owners manual cover but that is not universal.If you didn't buy the car new you can look on the back of the car to see if there is a dealer label or the original dealer name on the license plate frame and call them. They should be able to look it up from their records if you give them the vehicle identification number.If you don't know who the original selling dealer was, you can call the local Honda distributor (American Honda in the USA 1-888-999-1009) and ask them who the retailing dealer was so that you can call them to get the code.otherwise you have to have the navigation system removed to get the serial number off of it and that costs money.I hope you find the code on the tag in the gloveboxhope that helps"
Hope this helps!
このアンサーは役に立ちましたか?
スコア 6
4 件のコメント:
さんによる
+ excellent
さんによる
+ Great Research
さんによる
hey, I got a problem with my 2004 Honda Odyssey. Thanks to your last advice, I found the access code, but now the system require a dvd. I don't have it. I've had this car for eight years, so maybe I threw it out. Now I need the file with software from this DVD. Can u share it to me, please. Really, it is an old car and I won't pay 100$ for ori U4030-0075-209 :)
さんによる
コメントを追加
回答を追加する
jntief さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 21
今までの合計 4,135
